How do we add rider map to our Signature block?
Poppie65
The link from the outgoing platform doesn't work anymore. Is there an updated process to add a rider "States Visited" map on the new platform?
Thanks in advance!
Looks like you have to host it on another platform as it would not let me upload the pic file, just asking for a url.
I don't think you can upload picture files to the new platform. Images have to be attached.
The max size of an image that can be attached to this forum is 1 MB. If the image you created is larger than 1 MB, you may need to reduce the size.
If you can get the image you created on your device screen, then you should be able to copy it into your device files. Once there check the size. If it is less than 1 mb, then you should be able to attach it by clicking your user name on the top options line of the forum, then the signature option on the drop down. The software to attach images to your signature is on the top line of this forum in a drop down when you click on your user name.
Wow, I finally did something on this new format that worked! Normally when I go to insert a picture, no matter what I do, I get a message saying I did something wrong and it had to be corrected. I got most of the States in except for the upper NorthEast. Plan on leaving June 1 to finish that up.
Hopefully got it right now. Press Get a Link on the map creation page then paste that.
Yep, think you got it right. I can see your map at the bottom of your post.
Sorry I had to run out on you in the middle of it. Got a phone call. Had to go
to a town about 25 miles away to pick up a driver who was dropping off a truck.
