Brian, I know it's long, but it's well worth a read -
https://www.spyderlovers.com/forums...t-Do-s-and-Do-Nots-quot-for-new-Spyder-owners
And then when you do get a Spyder, it's probably worth
re-reading the bits that apply to whichever your chosen model/engine is. :thumbup:
Sure, they're different to 2-wheeled bikes, but once you really get a handle on riding a Spyder & get '
yours' set-up properly for you/to your satisfaction, you can potter along as gently as you like and never hafta worry about gusts of wind or invisible gravel, just enjoy getting your knees in the breeze without the worries;
OR, if you want to put the effort in, you can ride it harder & faster than you ever dreamt possible in the tight stuff! In fairly standard trim/on stock tires, it'll never be the fastest machine on the block simply due to all the extra air it hasta push ahead of it & all the extra weight it hasta move; but it will be at least as fast if not faster than most cages, and once it's tweaked to your satisfaction & got some decent tires on it & it's ridden reasonably well by an increasingly capable rider, it'll eventually out corner & out brake any 2 wheeled bike on the road as well as most other things besides; and at it's best,
IF YOU PROVE TO BE UP TO IT, it can even be the
absolute fastest thing thru the twisties,
IF your body is still up to putting in the effort required as & when required!
hyea: They're not only more stable thru the corners & on the less than ideal surfaces, they've also got a somewhat larger area of tire contact patch with the road & an extra wheel of brakes, giving you better braking potential/capabilities and cornering potential/capabilities, and when you learn the body english required to extract the best from one of these wondrous things, you too can have a real blast on them... Maybe a slightly different blast to that you might get from your 2 wheeler, but still an equal or possibly even better blast - those of us who ride them at
any level don't crow about the
Miles of Smiles for nothing! :yes:
And btw, if you want to ride a Spyder as well as
you can, maybe even push it right out to
it's limits &/or yours, you're probably going to hafta be a
LOT MORE committed, gutsy, and capable than any 2 wheel rider short of the top tier professionals out there! :lecturef_smilie: There's none of that centrifugal or centripetal force crap around to help you stay upright & corner at speed, these things will try their hardest to toss you off at every opportunity until you learn how to manage the massive cornering forces they can generate; there's none of that limp wristed chicken hearted easy counter steering stuff or just lean with the bike stuff... when/if you ever
really start to explore the capabilities of a Spyder you'll discover that you
NEED more core strength than any 2 wheeled rider ever needed; you'll
NEED to learn how plan & look well ahead then actively steer it safely thru every corner; you'll
NEED to learn how to move yourself &/or your weight around to match & then enhance it's capabilities; and it'll take much more effort just to stay on the thing than those pantywaist 2 wheelers ever hafta exert! It takes guts, skill, strength, and bucket loads of pure adrenalin to ride a Spyder to its limits/your fullest, and if you don't already
KNOW in the deepest parts of your soul that adrenalin
REALLY IS BROWN, try jumping straight onto a Spyder & riding it exactly the same way you ride that Honda now & you soon will! :yikes: And only
THEN will you be able to move beyond those 2 wheel biased ingrained misconceptions and limitations and discover the absolute
Joy of riding a Spyder in rings around those mere mortals on their lesser 2 wheeled steeds!! :trike:
So stop being an increasingly fearful aging wimp on a 2 wheeled machine, get yourself a Spyder or Ryker and be an exhilarated & excited aging rider on one of the greatest machines you'll ever straddle! nojoke It'll be hard (cos it's different, & you hafta 'unlearn' a bunch of stuff about riding that you currently take for granted
) and it'll take some time, most reckon on more than a couple of thousand miles to really
start getting comfortable with them, but maybe if you've ridden quads or snowmobiles a fair bit then you'll be able to get there quicker; but once it all falls into place, you'll wish you hadn't wasted all that time pussy-footing around on a 2 wheeled bike worrying about making the decision to take the big step & get a
REALLY EXCITING & CHALLENGING TO RIDE machine like a Spyder!
You KNOW you Want to, so get out there & BUY the damned Spyder so you can finally discover what you've been missing all this time!
hyea:
Just Sayin' :cheers:
....But, I feel so......weak, as a man, to go from 2 to three wheels. What kind of weak, limp-wristed coward am I?...
:roflblack: Maybe too weak for a Spyder? :dontknow:
Go on, screw your courage to the sticking place,
be a Man, and Just Do It! :thumbup:
Ps: Check out the
Enabled SpyderLovers section to see how others have managed -
https://www.spyderlovers.com/forums/forumdisplay.php?128-Enabled-SpyderLovers
and the '
UNSEEN DISABILITIES' thread -
