looking for a certain tire hope u all can help
scooterexpress
ok i'm looking for a pair a tires for the front on the rts but i want "raised white lettering" not (bsw) i've called around to few places done google search no such luck..anyone out there ever look into this or have seen what i'm looking for?
thanks for any tips or info
(p.s. bob i'm expecting you to the first one to chime in here with the right answer)
Have looked myself..!!
No luck so far and I have thought of just painting the ones I have. A little tire paint and a lot of time. Hang on some one may have done better than we have..:thumbup:
Tires
Have you triex Tire Rack?
QUOTE=rnet;573678]I will have my son check with his wholesalers in the morning.[/QUOTE]
This is the first that I've seen this one pop up! :2thumbs:
Let's hope that something can be found so that we learn from this.
How aobut some WIDE whitewalls?? :shocked: ;)
Only problem I see is when you need to rotate them....if they're directional, the RWL will be on the inside after dismount/rotation/remount.
White lettering
How about this?
Find a tire with lettering you like and do what we did long before tires came with white lettering.
One or two bottle of Testors Plastic Models Paint and two different size brushes(one wide -one thin).
As long as you don't scrape curbs it'll hold up much better than you might think.
How about this?
There are tire paints, crayons, and pens that will do much the same thing, too.
My front tires have 24000 miles woith no noticeable wear and no rotation. So not sure that would be an issue
My son found a couple of tires if you go with the same size that I have been using and have installed on several other spyders with no problems with a slight 5 minute fender adjustment.
