BlackWidow, are you referring to the rubber air tubes on the stock airbox? The tubes are acoustically tuned to lower throttle body and air intake noise. They also benefit from drawing cooler air near the front of the air dam.
The KewlMetal intake will flow more air but, with the plastic body panels in place, will draw more heat radiating from the engine. Clearly, not an ideal design.
And, personally, I'm not a fan of oiled filters (K&N, "Green" Filter, etc.) anyway. I've seen the filtration test results and the synthetic media filters are significantly more efficient and cheaper to maintain over the life of the engine.
I went with the synthetic aFe filter (manufactures the Evoluzione filter) and cut off the interior portion of the rubber tubes.
