OIL OVERFILL SOLUTION
danlnc
I went to the hardware store and bought a foot of plastic tubing about the size of your little finger. If I over fill the oil I just stick the tube in and then put your finger over the top end and then remove it with the oil in the tube. simple but it works.
Is it laziness or creativity ....... either way ........... it works
Same Idea behind Teddy having me keep a Turkey Baster in our oil change kits ............ you know ........ just in case :rolleyes:
I have a deal that looks like a grease gun but has a hose sticking out the end and you just pull back on the handle and it draws out the oil
