Blinc
I have an 08 SM5 model and while wife I were out riding around for a while last night the Spyder overheated. While I was accelerating from 1st to 2nd gear I felt something wet and very hot splash on my right leg, then my check engine light started blinking along with Hi-Temp, Limp Mode and Check DPS scrolling across the gauges. This was followed by a huge plume of white smoke. I pulled over, and waited a long while, then started the Spyder back up and limped home. It was too hot to mess with last night, so did some checking on it this morning. I pulled the panels off on the right side and checked the radiator bottle, empty. Not really knowing what the culprit is yet, I poured some fluid in the bottle and immeditely had a puddle under the bike.
From what I can tell it is coming out of the seam that houses the thermostat...see pic:
So, question is, do I have this towed to the dealership or is that an easily replaceable part? Assuming that is the only problem.
On another note, the DPS unit is bad on this bike and BRP says it will take a month to get one in to the dealership before it can be replaced. (missing the smokies ride because of this) Most of the time I do not have power steering, but have dealt with it, but I wonder if this is somehow connected to that issue?
So, I will wait for some true Spyderlovers techi help here before calling the tow company,
Thanks!
Thanks!
