Problem with trip meters - Regardless of which is selected, only No 2 shows on the dash! Any suggestions?
fulltimer
To start, this is on my '22 RTL, which is Stock., with No mods at this point.
I'm sure that I've caused this problem, but as I don't know how, I don't know how to correct it.
I use both 1 and 2 trip meters. No. 1 to show daily mileage, and No 2 to show how many miles on this tank of fuel.
Here is the problem. In the past, I could select which meter shows up on the dash with it's appropriate mileage by selecting in the menus. I could switch back and forth as I wished... Now, for some reason, only trip meter No. 2 shows up on the dash, no matter which one I have "selected"! I have tried selecting the meter I want and then re starting the bike to see if that changes the display. Nope!
Any suggestions??
First of all, I wish to applaud you, as you have mastered what for over a year I still cannot do. It seems that one must be an electronics expert to figure out the trip thing… or maybe I’m just used to pushing the button on my Harley’s speedo.
Mine was set on the trip part when I bought my '25 F3T, service had set it there. l tried my damnedest to get it to show just the mileage, but it kept showing either trip A or trip B. My salesman finally got it to show just the mileage, after about 10 minutes of trying to find it...
I don't know how the '22 RTL screens operate, but on the '24's, you touch the screen at the mileage location and it cycles between Odometer, Trip A, and Trip B with each press.
Well I found my mistake!!! PUSH the joystick in; then MOVE the joystick to the right, which will take you to the trip meters. Then to set the meter you want to show on the dash, PUSH UP! Sometime, when resetting the "B" trip meter, I pushed up and set it as the selected meter, but didn't know it. "A" is the one I have up most of the time. Dilemma solved.
I was about to tell you that, however I see you found it!!!!!
