I think this is my first question to the forum so I will try to do it right and not droll on..
I have a 2010 RT/SE5. Odo shows around 25K miles now, had about 16K on it when I purchased it. I have not replaced anything other than oil and filters since owning it (about 3 years). The fuel cap was a recall item that was replaced.
Yesterday when riding home from work, it began losing power quickly and even though the throttle responded, it was still coasting down to a stop. Got it down to 3rd and the engine quit all together. Pulled off, applied brake and it started back up, nothing unusual in the display. Downshifted to 1st and began home again. About 5 minutes later, same thing happened. It seemed like getting it into 3rd during downshifting actually coincided with the engine shutting off. Restarted, downshifted, took off for home. Got the rest of the way home with no other issues. That was about 20 minute ride at that point.
I checked it at home for codes (running at idle, holding mode and selector simultaneously while depressing turn signal) and nothing came up. Blank screen.
I have worked on a number of two-wheelers but have not tore into this tryke much as of yet. Any ideas or suggestions? Has anyone seen this before? I looked through the forums and nothing jumped out at me.
Thanks all.
Thanks all.
