Spyder suddenly shut down when I stopped at a light!! Started right up after a bit tho - ever happened to you? Any heat sensor do this? Any ideas?
Snoozer
I have a 21 RTL and was just coming back from Sturgis last year. It was hot and when we got to Denver there was stop and go traffic. When I came to a light the bike just shut down. No warning, no codes, it just stopped. I had to push it over to the side of the road and not freak out. I let it sit for a minute or two and then it started right up. The same thing happened a couple of weeks later. Hot day, stop and go traffic and come to a stop light and it just died, no warning and no codes. I let it sit for a minute and it fired right up. I took it to the dealer and the tech thought it might be a smog device so we took it out. No problems until Saturday and it happened again. My question is there some kind of heat sensor that might be causing the problem? I am all out of ideas.
Did the dealer check to see if the fans were operating properly. Let it run until the fans come on, and then check them to see which direction the fans were moving the air through the radiators?
You can easily check that yourself, but if the dealer was supposed to find the problem, they should have checked.
Very well, there should have been a message on the dash & a code that the dealer “should” have seen. My 998 did the same a couple times when the dash read 107°F, but the ambient was only high 90°s, and it did have a message & codes. The Water pump did fail shortly after. It's an Error not flushing/replacing the coolant at the 2yr mark. It was full, just old & watered down.
What smog device did the dealer remove?
Good question from Gwolf regarding fan operation. The fans should have been running in your situation. We could do a better job of helping if we could get come feedback.
Mine has done this when hot, or it stumbles and I goose it a little. I finally concluded that it is repeatable in stop and go traffic, always goes away after riding a bit, so must be related to fuel vaporizing. Fuel acts as a coolant to some degree and will keep the fuel system cooler when running, but fuel may overheat and vaporize enough to give poor injection when you're idling and the engine bay gets warm. My Spyder hasn't had it since I've been running better fuel (I was running regular, but the machine does run better during take-off on mid-grade, no pinging). It wasn't warm enough to cause fans to turn on (that only happens at idle) but generally when it's 95°F or higher outside in heavy traffic.
I have a 2014 RTL & it has shut down twice. Both times at exactly the same location, approx. the same temp, and only after riding about 5 minutes. It hasn’t happened again for months so I think it was just a fluke. Could possibly be something in the fuel line line or in an injector. A friend from our club had the same thing happen on one of our rides.
I’ve had wierd things happen on every bike I’ve ever owned.
