What did you do to/with your Spyder today?
I'd share pics, but they're too big. I just swapped out my rear tire on my 2023 F3 Limited 'cause the middle was shot. Got about 18,000 miles, so I'm good. Took me 30 minutes to get it off the bike – the shop didn't think I could do it in an hour! Got the new Kenda Kanine, and the dealer filled it to 28psi. Feels kinda rough on the road. Someone at the shop and on Facebook said my old tire wore out in the middle 'cause it was overinflated. I ran it at 15-20 psi, so how's that too much? What pressure are you guys running in your F3 Limited with the Kenda Kanine?
Run OEM Kenda/Kanine Kenda rear tires at 28#. They need that PSI due to single ply sidewall...
You really should do a search on Tire Pressure, and spend a few hours reading, but briefly, the Kendas and their clones, including the Kanines, Arachnids, and others, are simply lightly constructed and not greatly quality controlled car tires, and they NEED that 28 psi to carry the Spyder due to their light construction! No matter how low you run their pressure, you will still wear out the centre of the tread on the rear. This is because the lighter plies they use just aren't strong enough to stop the centre of the tread ballooning out when they rotate at anything much over about 20-25 mph, and the faster they rotate, the more they balloon out, so you end up only ever really running on the middle 2-3" of tread, which wears out quickly as a result! :cautious:
And that lightweight construction, which really NEEDS 28 psi +/- 2 psi or so just to carry the load of your Spyder, even before their poor quality control issues come into play, means that running pressures as low 15-20 psi in a Kenda or any of the clones is DANGEROUS and could lead to catastrophic tire failure!! If you did that for any length of time, you were pretty lucky to get away with it, but if you ran it that low and it still wore out the centre, then you are just another of the many who have found out how crappy the Kendas and their clones are!! 😖
If you run 'real' car tires, quality tires that are actually capable of carrying the weight/loads of a normal car at 28 psi, or about 3 times the weight of a Spyder, then they don't need that much pressure to carry the lighter load and you can run 18 psi in them, which will keep the whole of the tread contact patch on the road much better, and you'll get better ride, handling, traction, tire life, and more - but it's NOT SAFE to run 15-20 psi in a Kenda &/or any of their clones and even if you do, you'll STILL wear out the centre of their tread first!
Ps: Check out this thread on posting pics as thumbnails:
And this thread for all sorts of helpful info on the Forum, including resizing your pic/image files:
Rode it - 824 miles in 14-1/2 hours from the Southern tip of Texas to Clarksville, AR, to attend a meetup with some folks from the Honda CTX1300 forum. Would have been quicker, but I had to stop in Nacogdoches, TX, for about 40 mins to let a mean-looking storm front pass by. Then I got to ride most of the rest of the way on wet roads.
Tried to figure out where to mount these lights so I could create some brackets:
View attachment 251677 - View attachment 251675
The controller it came with sorta sucked (5mA of drain when off, high/low beam selection only by toggling power, no ignition control, etc.) I ripped it out of the box and made my own "controller" with 2 relays. Low beam will be controlled via external switch, and high beam will be controlled by Spyder's high beam switch. Lights will only operate when key is on.
View attachment 251672 - View attachment 251674 - View attachment 251691
I mounted some similar lights. See if this post is of any help.
Nice! I also tried many different brackets and none of them worked for me, so I decided to make my own. The height of yours (~12-13 inches) is perfect for fog lights, but mine are driving lights and must be >=16 inches. The challenge was finding metal that was both thick enough to not flex but still be able to be bent into the proper shape...
I'll be posting photos when I have them mounted (wiring will take quite a while longer though)
Edit: got 'em mounted! A bit janky, but at least it's sturdy! Finally got a use for those useless 1" 12-point sockets.
ResizedImage_2025-09-26_12-41-30_1.jpg 😁 ResizedImage_2025-09-26_12-41-02_1.jpg 😁 ResizedImage_2025-09-26_12-44-00_1.jpg 😁 ResizedImage_2025-09-26_12-42-37_1.jpg 😁 ResizedImage_2025-09-26_12-56-03_1.jpg
View attachment 251733 😁 View attachment 251734 😁 View attachment 251731 😁 View attachment 251732 😁 View attachment 251735
Very nice!
What did you use for the mounting brackets?
Well, we were supposed to be having a tech day at my house today, but due to the front coming in, we have had light showers all day. But I did get a chance to install the accent light in the front that I ordered from Slingmods, and I installed my rack for the extra storage that I will be needing for the trip to Maggie Valley in 2 weeks. It looks a little further off in the pictures, but I need to make a slight adjustment of about 1/4"-1/2" in order to center it. I will snap more pictures once we pack up and I have the bag strapped on the rack. This thing is a life saver when taking the wife on trips.
Took my 40 year old son for a ride today, he liked it. Also got a chance to see if I had set the preload on the new front shocks correctly. Had to have two up heavy, engine running and self leveling active to make sure I had between 3.5 and 4 inches of clearance at the middle frame and I did have better than 3.5. Wife tested it with a pole mounted to a 3.5 inch wide PVC fitting and it cleared and when I bounced I didn't bottom out on it. That worked out to free length of the spring on a Baja Ron shock right at 8 and 7/8 inches.
Ron was great, I called him after I installed the shocks and found one was too hard to move the adjustment ring with the supplied spanner, in fact I broke the spanner trying. I had to drip some aluminum tap magic (oil of wintergreen) to get the threads to slide better. Ron sent me a new spanner and wanted the old one back. We also discussed the free length as the shock comes out of JRI production. Ron was trying to get it set so you really would not have to adjust it much. Mine out of the box did not even give me 3.5 inches unloaded so I had to crank the ring quite a bit. Ron says they are shooting to have a consistent 9 inch free length when shipping.
Started wiring up my lights. Went on a small radiator-cleaning side quest. Just blasted it with some foam, scrubbed it a bit with a large brush, and rinsed it off.
before:
after:
I finally got my Spyder out today for a ride, did mostly country roads. Sunday is always my favorite day to ride. l don't see many cars, but lots of Amish Buggies, going and coming from their Church Services. Most of them know me, recognize my Spyder, and always wave. l also love going by their red, country school houses. I went by one a little ways outside of town a few days ago, and there were about 10 to15 kids of all ages waving at me as I went by... 😊
Rode from Greensboro, NC to Maggie Valley for the rally. I know I am early but that is on purpose. I will take a long ride up here tomorrow and be ready for the rally on Tuesday.
Nothing to the Spyder itself, but I downloaded my planned routes to my Garmin XT for my trip on Thursday. Not that I really need them, as we do this ride every year. This is our annual Devil's Highway ride in Eastern AZ. This year, it looks like we will have around 20 guys going. There will be riders from Canada, Wisconsin, Texas, California, Missouri, and a bunch of us from Arizona (Phoenix and Prescott area). This is just a quick 4 day trip, but still a great time. I will most likely be the only Spyder. Most of the riders will be on BMW's and a few Goldwings.
I added an Admore light bar and a backup camera (NOT the BRP one) to my 2024 RTL.
It was a bit of work as I ran into some issues that slowed me down:
- There is one fastener that holds the rear panel on that requires a small nut driver. None of my tools fit.
I am not sure why BRP couldn't have just used a Phillips or torx rather than a nut as it would have made life MUCH easier.
- Try as I would, I could not get the picture to display when putting the Spyder in reverse. I spent a lot of time with a multi tester trying to diagnose the issue. I finally found the cause. I have a Show Chrome electronic fuse block (which powers a few of my accessories). Unfortunately the "plug and play" connector provided does not account for all wires/pins. I had to create my own "jumper" for the 2 wires that the adapter did not account for.
