Just installed the BajaRon end links. I seem to recall reading elsewhere on these forums that a magnet might be useful when installing the spacers. My spacers were not magnetic (e.g., austenitic stainless steel). My 12 inch hemostat made quick work of it.
I also used a step drill to bore a hole in the front of the frunk (in the weatherstripping) and wired in a battery tender charging port so my wife doesn't have to take the hood off to put it on the tender. Much easier and cleaner, in my opinion.
Spygoat,
obviously those of us in cold weather have to put the battery on a tender over the winter storage months. Given that you've gone to the quick-connect, I presume you/your wife also put your Ryker on the tender whenever you park it.
Do you have previous experience with parasitic current draw on your Ryker draining your battery?
If so, how long between starts does it pull down to the point of needing a jump? A week? A month?
Thanks,
EV
Spygoat,
Thanks,
EV
Did the RickD daytime running light mod (with some tweaks) and installed a remote battery tender plug in the frunk. Not bad for a rainy day BS tinkering session!
I wired the DRL right into the accessory lighting circuit, so it comes on with the bike and goes off when your marker lights go off after shutting down. I did not use a handlebar mounted switch, it is all automatic. Compliments the Elite LED headlights very well!
Looks great! The color temp of the DRL is a good match with your headlights. In the charging port photo, what keeps your connector from falling out?
