Pampurrs
Pragmatic Member
If I was to do this on a 2015 with the new gauges, I would run a proper 12V line.
Bob
How would I do this, Bob? :dontknow:
Pam
Bob
Pam
Not to disagree with finless, but I have used the dash wires on my last 4 Spyders for a voltmeter with no problems to date.
cruzr joe
Oh I see where you got that. But if you scroll down to the product description, it says that its 2 inches. It actually fit perfecly into the opening.
Thanks for pointing that out.
Pam
I think you have that wrong Bob.
The 2013 temp gauge has 4 wires like you said but are not as you describe.
Two 12V switched from the same source junction in the harness. Both are the same color. Orange with a red tracer.
One wire from the cluster.
One common ground.
I would assume that one of the 12V line was dropped. Since they are both the same anyway. It still can be used for a volt meter.
cruzr joe
Finally let me just state something. That is true battery voltage vs the switch 12V coming out of the regulator.
Your volt meter will read lower if you tap onto the gauge wires and thus not the true battery voltage. Fully charged battery on the gauge wires reads about 12.4. At the battery it's almost 13V. At least it does on my 2011. So if you want your true battery voltage, run the lines to the battery with a fuse. A
Bob
The battery in yours is in the frunk so running a wire down to it shouldn't be too hard.
Pam, I think you bought the same gauge as Cruzr Joe and I have. For you I would say go ahead and hook it to the orange wire for the gauge.
Bob
If if you run right from the battery, won't the gauge be on when the bike was off?
Thanks to some sage advice from one of the SpyderLovers, I have solved how to do it. I am plugging in a "Add a Circuit" on one of the switched fuse locations (r6) , then running a red wire from that added fuse up to the voltmeter. I will also run a black wire from somewhere on the frame of the Spyder to use as the ground.
http://www.amazon.com/gp/product/B001QRSBW0?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
I also ordered a nice digital volt meter on Amazon. I didn't really care for the look of the one I got.
http://www.amazon.com/gp/product/B006G52A7O?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
This will be my Monday project
Pam
I'm sorry but that is just an awful idea. How the heck are you going to keep the water out of the fuse box afterwards. Don't ask for trouble. Just use the orange and black wires from the gauge plug.
I'm curious how this will cause water to go into the fuse box. I'm not arguing, I respect your advice BillyBovine. I'm just wondering what you mean by that.
Pam
Both fuse boxes are located behind the front trunk. Fully exposed to whatever mother nature and your garden hose can do to them. BRP issued a TSB for 2013's for new fuse box covers to try and keep the water out. Same design in later models like yours. So don't start poking a hole in them to get a wire out.
Pam
hi
can you post how your project worked and pictures would be great.
i'd like to do the same mod.
