yousi. exhaust
Larry t
can the baffle be remover from yousi. exhaust? it has a bolt in the tip but appears to have a spot weld keeping it from turning. Thanks for replys
My Yoshimura (and all the ones I've seen) do not have a baffle. Mine, and many others, do have a DB reducer that restricts down the outlet hole. Mine can be removed. I don't know about all of them. Some (especially those provided on OEM machines) may be tack welded. You can always grind off the weld and remove the restrictor.
