2010 RT SE5 digital gauges working and volt gauge hooked up
peterRT
Hi Guys", I disconnected analogue gauges and put in a digital volt gauge too.
Now I will see how accurate the digital gauge is.
Did the same thing to ours with the same gauge. It will also show you, are your battery gets older and worn down when you need to replace it because you can watch the voltage drop under load when you go to start it.
