Welcome to posting
@Chrisshumaker. Sadly, I doubt you'll get a response from
@RazorV, who last posted May 2022 and last visited the Forum in June 2022, or about 4 years ago now!
And the other poster asking about this problem in this thread,
@Derby713, hasn't been back on the boards since August 2024...
This is why it's always important to check the date of the first post in a thread; the last few posts in the thread; and any specific posts you want to reply to/ask questions of the poster, all before you reply.
Still, re your problem - if the noise you're getting is a 'just the one clunk' type noise on first selecting a gear from Neutral (ie. First or Reverse) after starting up the engine, then that's a normal feature of engaging the 'not yet turning' constant mesh gearbox that our Spyders have - you might be able to reduce it a little by choosing the right oil, getting the oil warm first, etc. but you probably won't ever get rid of that initial clunk entirely (there's a whole lot of discussion on the Forum about it, just search on '
Clunk' with the '
Search titles only' box checked - Search is up in the top right of each page.
) In fact, because
that particular clunk is the nature of the gearbox/a feature of basic physics (ie. engaging a running engine with a not yet turning gearbox is applying a force to a standing object - and a thing at rest will try to stay at rest unless there's a force applied) then you should probably be a little concerned if that single clunk on first selecting a gear goes away entirely!
Then there's the 'short duration chatter' that some Spyders, particularly V-twins, get when you first try to move off - that chatter noise that usually only lasts a second (or maybe three, but not too much longer) as you begin to move, then goes away fairly quickly and doesn't really happen at any other time. That too is basically normal, it's the nature of the stacked clutch plates gripping and releasing as they first take up the pressure of drive. If it's of short duration, doesn't continue for 10+ seconds, then it's likely perfectly normal; and it's often made worse if you back off in alarm at the noise, but still keep a little throttle on, instead of either gently powering thru it or backing off entirely. IIRC, the clutch recall in 2013 or so on the V-twins upgraded the clutch to ensure this wasn't an issue.
However, if your noise is a 'more than one clunk' noise (&/or a 'machine gun' type rattle on trying to accelerate in any gear, associated with a lack of immediate response to increased revs) that only happens after you've selected a gear and when you try to accelerate, especially if you try to accelerate hard, then the rest of the earlier discussion in this thread may well apply. It could be a clutch issue; it could be a sprocket issue, front or rear, possibly a worn or damaged sprocket; or, as I mentioned toward the end of the last page and as has been discussed a bit more above, it could be a loose or worn belt skipping teeth on one or both of the sprockets. Now that more Spyders are beginning to get up in milage on their original belts, I've recently begun to notice that last one becoming a bit more of a growing trend, not yet a biggie, but maybe on as many as 6 Spyders now - I can't recall seeing it on a low milage belt, or even just a loose belt -
yet, but if the Spyder concerned has over 150,000 miles or so on the belt, and especially if it's been worked hard, then because of those I have seen, that's probably one of the first places I look to find the source of a lack of drive and a 'machine gun' type rattle now! If it's
NOT that worn belt/sprocket issue, at least I've eliminated the simple things first.
Over to you!
