Given those results Deanna, with the annotation from the Analyst that 'Engine wear levels appear satisfactory for the first sample' and that the greatest benefit of these sort of tests comes from the
TRENDS that regular testing reveal over time, I'd be pretty happy with those results from your Spyder - for now!
hyea:
Sure, the Sodium levels reported are a tad high, but those can be caused by any one or a combination of things that don't necessarily have anything to do with abnormal wear in your engine; and
Yes, you
should check for a possible coolant leak, but a water contamination level of
LESS THAN 0.05% could be simply caused by your sample being taken when the oil wasn't quite hot enough &/or it was taken on a humid/damp day!!
  Similarly, Viscosity levels of cSt 10 @ 100°C in a 10W40 oil really isn't anything to worry about... for now. :lecturef_smilie:
So keep an eye on your coolant level & check for leaks, maybe even put a large sheet of white paper under your Spyder whenever you park it (especially over its winter storage.
 ) just to see if it shows up any drips; and next time you do an oil change (earlier rather than later, as recommended) take another sample and send it off to the same place to get it analysed in order to see what might have changed. Apart from the potential for identifying imminent catastrophic failure (
which your oil analysis DOES NOT SHOW!) it's the
TRENDS over time that will really give you the most information from regular oil analysis! :thumbup:
And in the meantime....
Ryde More, & Worry Less!
hyea:
