Thanks but the F3 model does not have a Schreader valve.Also, is your battery in good shape? Not sure if the 2022's used the cheap Chinese batteries or not, but they can cause comms issues that force error messages. Most likely the compressor/suspension, the one I would add to the post above is to make sure the Schrader valve in the system is tight and not leaking.
Check for leaks right off I believe I found the problem there was a bad connection at the compressor.How is the ride of the bike when it throws that message at you? Is it bottoming out? Can you feel, or hear the compressor when it kicks in, does it seem to run a lot of the time when you're riding it? When you go out to use your bike, before you start it, lift the seat to get to the schrader valve and put a tire gauge on it and check the pressure! There should be some air in the system after a rest overnight, if it has no air then you have a leak somewhere. Break out the soapy water and start to check the whole system to find the leak! Come back and tell us how you made out! Good Luck!
Do not surmise that this might be the only leak. Back in 2021 when I bought a new 2021 RT LTD, there were actually four leak faults. I'm not say you should be so unlucky but if the leak has been for a while and therefor the pump has been running continuously, be prepared that the pump may have burned itself out.Check for leaks right off I believe I found the problem there was a bad connection at the compressor.
It will work great, till it doesn't!!! That's a proven fact, and how much do you want to chase your tail is up to you! Me I want to ride and not have to go through that hassle ever again, been there done that!! Good luckThe Schraeder valve is already there, it's under the passenger seat on the right for most air suspension Spyders. You would have to blank off, or bypass the pump to seal the system.
However, I like the air suspension. After the initial problems I had, the system works very well and I appreciate it a lot. On my new S2S it works very well and is supremely comfortable and copes with the bike being loaded or not.
Obviously for an F3-S the objectives and riding style might be very different than for a Sea to Sky and a manually adjusted system might be a better use case; for me, I like the automatic system.
Using the Schraeder valve underneath the seat and eliminating the pump still leaves the airbag, and all the piping still in place as possible failure points. The air bag and the pipe work are failure points all of their own.It will work great, till it doesn't!!! That's a proven fact, and how much do you want to chase your tail is up to you! Me I want to ride and not have to go through that hassle ever again, been there done that!! Good luck
Does removing the pump and integral bleed off valve assembly, or even bypassing it, cause suspension fault codes?
I presume you would have to remove the ride height link on the swing arm and set it in a position relative to its sensor so the ECU always thinks the ride height is permanently correct? The ECU might be awfully confused as it reads from measurements from the ride height sensor and the pump with the integral bleed off valve fails to respond to subsequent requests accordingly by altering the ride height back to the normal level.
Just bypassing or removing the pump assembly is only part of the complex system of feedback loops.
Well that was my experience at any rate. In the end it was easier just to replace the pump and have the system working. I suppose you could rip the whole system out and replace it with a suitable length shock absorber with an external preload and damping controls.
That's what you don't understand, when I said put the schrader valve on the system, I meant ripping or disconnecting everything BUT the bag and hooking straight to the bag with the schrader!! You just unhook the dump valve, get a coupling, and hook the pipe from the bag to the schrader! Easy as pie, then all you have to do is find the right air pressure that fits your riding style! Some of the models are already set up this way, and they work just fine this way! Too many folks think this system is some sort of magic system that will give you the perfect ride and comfort that you can't live without, but if they want to mess with compressors, then good for them - not me, and a LOT of other people feel the same way as me! It's just another thing to mess up a good day of riding, ask me how I learned this!
Did you have to decouple the ride height sensor on the swing arm and force it to be the right static height so the ECU wouldn’t keep sending instructions to the compressor and outlet causing fault codes because there was nothing there to respond? Or does removing the compressor just disable the whole ECU’s idea about equalizing ride height?That's what you don't understand, when I said put the schrader valve on the system, I meant ripping or disconnecting everything BUT the bag and hooking straight to the bag with the schrader!! You just unhook the dump valve, get a coupling, and hook the pipe from the bag to the schrader! Easy as pie, then all you have to do is find the right air pressure that fits your riding style! Some of the models are already set up this way, and they work just fine this way! Too many folks think this system is some sort of magic system that will give you the perfect ride and comfort that you can't live without, but if they want to mess with compressors, then good for them - not me, and a LOT of other people feel the same way as me! It's just another thing to mess up a good day of riding, ask me how I learned this!
Yup, you are going to have to take off that right side panel, if you have a RT, it's tight but what I have done is take the dump valve right out so you can unhook the lines and wire that feeds it, you have to push in hard on the end of the fitting while you pull on the hose, may be wiggle it back and forth and pull, it will come out! Or if you want to do it the fast way, take a sharp knife and square cut the hose so you have a good square cut, take the sharp edge off the outside of the tube just to break the edge so when you hook the lines together, they will slide easily into the coupling! Go to any auto supply house that sells airline parts for a big trucks or go where they repair big trucks and hand them a piece of your air line and tell them you need a coupling! Make sure that the line from the bag, and the line from the schrader are long enough to hook together, if not you will need some line from the parts houses also with the coupling, take the line off the schrader extend the line and hook it the line to the bag.I’m looking at doing the same thing, as my pump is not working. Where did you find the coupling to connect the line from the schrader valve to the one that goes to the air bag? It’s a tight fit, but from what I can see, it can be done without disassembling the whole rear bodywork.
I have never had a code problem, and I have never unhooked the dog bone! It will ride flat once you find the pressure that works for you, it's never been a problem yet! It never threw a code when my pump went south on me in the middle of a 200-mile ride and Mother and I came home basically dead on the frame!!! Now do you want MY opinion of the stock rear SHOCK, if that's what you want to call it!!! It's a CRAPPY system when it fails, great when it works!!! A smart man with a little cash would put a good adjustable coil over shock back there and leave the bag as an overload system for heavy trips! Only put enough air in the bag so you don't pinch a hole in the bag when you don't need it! Load it when you do!! Ok, I am off the soap box!!!! Good Luck!!! Keep it stupid simple and ride more worry less is how I roll in life!!Did you have to decouple the ride height sensor on the swing arm and force it to be the right static height so the ECU wouldn’t keep sending instructions to the compressor and outlet causing fault codes because there was nothing there to respond? Or does removing the compressor just disable the whole ECU’s idea about equalizing ride height?
Thanks for that description It is an RT so space is tight but I was able to do exactly what you described yesterday with a fitting from the hardware store. I still have a small leak somewhere though as I slowly lose pressure after several hours. Could be a hole in the bag or the fitting at the bag which I can’t access. Thought about trying slime to see if it would seal the bag if it is indeed a hole in the bag.Yup, you are going to have to take off that right side panel, if you have a RT, it's tight but what I have done is take the dump valve right out so you can unhook the lines and wire that feeds it, you have to push in hard on the end of the fitting while you pull on the hose, may be wiggle it back and forth and pull, it will come out! Or if you want to do it the fast way, take a sharp knife and square cut the hose so you have a good square cut, take the sharp edge off the outside of the tube just to break the edge so when you hook the lines together, they will slide easily into the coupling! Go to any auto supply house that sells airline parts for a big trucks or go where they repair big trucks and hand them a piece of your air line and tell them you need a coupling! Make sure that the line from the bag, and the line from the schrader are long enough to hook together, if not you will need some line from the parts houses also with the coupling, take the line off the schrader extend the line and hook it the line to the bag.
The bag is only rated for 90lb and you can pump it up carefully, no more than 90lbs!!! I found that for me and the bride 65-70 psi is a good number!!! If you ride solo, 40 psi may be what you need, but that you will have to play with until you find the magic number for you! And of course, wrap all open plugs, watertight them, and check the whole system with soapy water for leaks!! The last one I did for a friend took an hour, but it not being my first one helped a lot!
Ps: make sure you push that line all the way into the fitting till it's in all the way, it will go almost 1/4"-3/16"! Trust me, it sounds harder than it really is!!
