MakoShark2
So got my second oil change (yearly one) at the dealer not long ago.
And I think the maintenance guy kind of likes to overfill it... When I got home just check the oil level and it was above the upper marker.
So I gradually pumped out about 3.4oz/100ml more or less each time (ride it a bit and rechecked)... Needed 4 rounds of this, so removed about 12oz/350ml of oil to get it above the upper marker.
![20191229_183029[1] copy.jpg 20191229_183029[1] copy.jpg](https://www.spyderlovers.com/data/attachments/93/93743-c40c00180a729cf60a627cb63377a3e2.jpg?hash=LF0ejl7Hbk)
All measurements done at home after a long ride, let it idle until the fans came on and checked within 2 minutes of turning the engine off, as I think it is the recommended procedure.
And here's the awkward part... During my last ride I just stopped on the side of the road (after riding all day), pulled the stick and for my surprise level was just on the tip of the stick... I did put the stick in a couple of times, rechecked and the same...
Can't tell if the ground was leveled, but that really confused me. Stopped again further on the road, let the engine idle until the fans came on, shut the engine off, waited about a minute and rechecked the level which was up to the upper mark...
So what the heck did happen here? Anyone could explain me this?
Does the fan thing is mandatory? Even when I'm sure the engine was hot?
Must the floor be perfectly and absolutely straight?
Not sure know if I should put that 12oz/350ml back or not.
Can't tell if the garage's floor (where I did all the measurements at home) is absolutely 100% straight (got to check that) but if any the inclination is very slight as I leave the Spyder there with no parking brake and it won't move.
By the way I know for a fact that the maintenance guy usually tops it with a bit more than the recommended, on the first oil change he told me himself he normally adds an extra 9.2oz/275ml (go figure...)
Thanks and Happy New Year from Western Europe!
