Is the Alternator shaft squeal just a nuisance, or is it damaging anything?
OK thanks, although in Canada, this machine is like me, not running in sub-zero temperature 😂
Running in sub-zero is not the same as starting an engine that is at sub-zero temps. It's only the oil temperature at startup that has bearing on the low number of the 2 in multi-viscosity oil. This is because once you start the engine, the engine heat will bring the oil temperature to operational levels.
