Loose mirror
spydercowboy
​My wife's 2012 RT Limited has a loose left mirror. Is there a screw inside that thing and how to you get to it if there is?
Question: By "loose"; do you mean that the housing isn't tight to the body of the bike, or that the mirror is loose within the housing? :shocked:
The mirrors snap in place with two spring clip and a keyhole latch each. It not snapped down at both bottom and front, they will be loose. If they are snaped down, then the springs are probably bent a bit. If the mirrors are removed, the two spring wires on each clip can be straightened and squeezed back together. The keyhole latch can be damaged if you don't remove the mirrors gently and correctly, so if you are uncomfortable with it, it would be better to swing by the dealer and have them do it or show you how.
I've got a wobbly left mirror also. At speed it is hard to see clearly in it with all of the vibrations. Today I did the matchbook under the table leg fix and stuck a piece of foam type paper in between the mirror and the body. Very high tech isn't it!
