NHTSA Campaign 26V575000 - 2025-2026 Spyder RT, F3, & Canyon freezing cluster fix issued
I down loaded the update while the bike was not running with my small charger hooked up. It down loaded OK but the "Install Update" box was grayed out. I shut the ignition off as the battery terminal voltage was 11.9 and left it on the charger for an hour. Came back and tried the update again and it was grayed out still. Started the bike and it finally allowed me to perform the upgrade. No surprises other than it did change the audio output to speakers vs. headset that I always use.
If you don't use the USB A port for data, or perhaps Bluetooth connections, you might be OK.
The problem with the display going dark might be extremely dangerous, so at some time you might have to bite the bullet, put the wooden hammer away, and take it to the dealer.
Whole reason I bought a 2024 was for ACP since I moved cross country and the navigation is a huge bonus for me. It's not so much as it goes black, but if freezes up. No speedometer, no odometer, no gear indicator, etc. Losing ACP is secondary although still highly annoying. I then either have to pull over, shut down bike, restart and hope it works the next time or continuing riding for 20 minutes at which point it usually crashes and reboots the head unit.
The few updates I have gotten to work before it seemed to require the engine to be running to have sufficient voltage. Which I'm fine with, but I can't get past the "no update found", even with the engine running. I am still thinking they are slow rolling the update just in case there's any issues they don't brick everyone at nearly the same time. I will just keep checking every day for a week or two and if it still doesn't show up I'll think about going to dealer. I'd almost rather just deal with it until I *have* to take it in, like for a new tire or something.
Also, contacting Can-Am is pointless. I wrote to see if they can confirm that the update is being rolled out in stages.
First they said just take it to dealer. Then 2nd email they said my VIN isn't part of the recall. But when I go to Can-Am's VIN recall checker page and input my VIN, the recall notice shows up as expected. Sigh.
It did that to me with the bike on the Battery Tender. I even checked the battery voltage before I started and everything was fine.
So, I turned the bike off, took the key out and away from the bike and left it for a couple of hours while I went and got my COVID and Flu shots.
Came back, turned it on and everything completed just fine.
Did about 120 miles last Sunday with the new update installed, no real issues except - I tried to access my distance and mileage via the trip odometers while riding, and the miles per gallon read perfectly, but everything else was wrong. I got home, shut everything down, then restarted because I was going to reset both trip odo's after the ride, and they had registered the info for the day properly. I knew from the regular odometer and my Garmin about how far it should have been. Oh well, we'll wait for another update...
Rode to CC Powersports for the update yesterday, all good now, near as I can tell. Enjoyed a very nice visit with some folks who are riding the wheels off their Sea to Sky.
Sarah
I ride a 2026 RT S2S and before this update and it was a hit and miss when it came to connecting to ACP. If you lost it in the middle of the ride, you would need to stop, turn off, and restart. Now I can't get ACP to disconnect! While riding down the road, I can disconnect the USB cable from the phone, plug it back in, and reconnects in seconds. Since installing the update, I've ridden about 1k miles, turned it on/off about 30 times, and each and every time it connects. I'm using a 36"cable - no need for the 6"cable. I always thought it was a software issue and not hardware. It took BRP some time to get this right, and this rider appreciates that BRP finally got here.
Everybody mentioning the new update number as V6.1.0, are you sure that is the right version?
Here it's V6.0.1, and I would be surprised if there are two different versions out there??
