If the oil only had 200 miles on it when you tested it and it showed oxidation at 37 I would tend to question the accuracy of that test?
If the oil had 9000m on it when tested and it was changed then, your fresh oil should be fine, but you may want to try a test earlier (say, 4500m?) to see if the oxidation number is more normal. If yes, continue on without an oil change; if no, then you may want to reduce the interval a bit?
Depending on your level of concern you have 3 choices: ignore, retest, or change the oil.
I have had my oil analyzed twice now, once with XPS at 8,900 miles and now with 9,000 miles on Amsoil. The XPS came back critical for viscosity 8.7 which equates to 20 weight oil. The amsoil came back for viscosity at 12.3 which is very close to 40 weight oil. This most recent amsoil was critical for oxidation (37) where XPS was at 10. There comments were: "Oxidation is at severe level. Drain interval may be over-extended or unit may be running too hot. Elevated Oxidation causes acid by-products, deposits, and sludge, and can increase viscosity and wear." Should I be concerned about this and does anyone have any other thoughts? The spyder has 43,000 miles on it now and the oil was in the spyder for 8 month and 9,000 miles with no observed mechanical problems other than the cam position sensor went out a week after I changed the oil. The oil tested had 200 miles on it when the cam position sensor went out, but it wasn't tested until 9,000 miles.
Do the reports show a Total Acid Number or Total Base Number (TBN or BN)? Here are a couple of good articles about oxidation in engine oil. https://www.infineuminsight.com/en-gb/articles/testing-engine-oil-oxidation/ and https://www.chevronlubricants.com/e...ment/used-engine-oil-analysis-tbn-vs-tan.html.
The info I find states if the base number drops below 3 then it's time to change the oil. I wonder how your lab determines the oxidation number, and what does it mean? Oxidation causes acid to build up in the oil and the base number is a measure of well the additives in the oil neutralize the acid. My oil reports don't show TAN nor oxidation which make me wonder how valuable that number is. How about posting the entire lab report here? I think several of us would like to see it.
Thanks for posting the analysis, it is difficult to read but the comments in the upper part is where they talk about the oxidation number and not the TBN (total base number) which usually indicates how much protection against acid formation the used oil still retains. It might be helpful to ask the lab how or if oxidation relates to TBN? Amsoil usually has a higher TBN to combat acid formation.
The second comment is about minor fuel dilution which is at 3.? percent and the viscosity being reduced a bit. The cst reading converts to a 30 SAE wt. so definitely in the 10-40 range.
Did you take this oil sample after a long ride or just after a short warmup? The reason I ask is for me its unusual to see fuel dilution in a gasoline oil because it would tend to evaporate once the oil is up to temperature. If the oil was hot you may want to resample at a shorter interval and see what the analysis shows? Maybe you have a leaky injector but that is just a SWAG not a reason for concern if the engine is running well?
Perhaps someone else can shed some light on this analysis?
I suspect BRP chose 9300 miles because that is almost exactly 15,000 kilometers in Canadian money.
I suspect BRP chose 9300 miles because that is almost exactly 15,000 kilometers in the Rest of the World.
 ) but also for the rest of the World too!
 ) but also for the rest of the World too!  hyea:
hyea: The moisture accumulation is not huge, even in a high humidity environment like I have here in Tennessee. It's not like you're going to get a cup of water sitting at the bottom of your sump. It's more like a light dew which forms on engine surfaces above the oil line. However, even a small amount getting through the oil film to vulnerable iron parts can be significant, over time.
If you do your oil sample correctly (hot oil, mid-drain). Chances are that any moisture will have vaporized before the oil sample is taken.
Where the effects of water show up is in 2 places. As the bike sits, moisture can and does accumulate. If the oil does not adequately protect ferrous metal parts, rust will form. When you start the engine, this rust will be removed and washed into the oil. It is much too fine for the filter to remove and shows up as increased iron content in the sample.
There is a 2nd indication that your oil is not providing adequate protection from the inevitable moisture which accumulates in an engine/transmission with long periods between being brought to operating temperature (the oil, not coolant). Because moisture reacts with gasoline impurities in the oil to form a corrosive mixture which will attack other, non ferrous metals like Aluminum and Copper. These will show up in an analysis as well.
Too many falsely think that bringing the coolant to operating temperature with a high idle over the winter is a good idea. This practice has many downsides, including the possibility of making oil issues worse. It does have the single advantage of sending lubrication to parts that may have lost their protective coating. This benefit depends on the quality of the oil. Lesser oils tend to drain off and leave parts unprotected.
If you can't get out and ride far enough to get the oil to operating temperature. It is best to let your bike sit. Letting it run at idle for 15-20 minutes does more harm than good. The oil will not change temperature and remains cold. You can't burn off the moisture this way.
The OP's experience is similar to mine. Though my Spyder sat without running for 4.5 years. My oil sample came back with flying colors, just as his did. Not a comprehensive spread. Just another data point to throw into the mix.
I ran my oil for 10,000 miles and just sent a sample in for analysis. I use Amsoil 10W40 and I have 60,000 miles on the spyder. Why did BRP pick 9,300? Previous analysis at 9,300 returned still usable. What would another 700 miles hurt? We'll see how it comes out.
What was the viscosity?
