Trailering the Spyder - could use some tips on fastening it down?
All good & each tow will vary per person & experience/acceptance levels. The dealer will (should) hopefully assist & default answer: read the manual **<strap through the rim - not the brake rotor>**. Too bad you're not ryding back - but each their own, glad you have an option & for asking. Enjoy your new toy.
Up here in Northern Ontario the weather is still a bit iffy or I would definitely be riding back. This was a private sale so I’m most likely on my own, I’ve never even sat on one, let alone ridden one, so hopefully I can at least get some direction on getting it up the ramp and onto the trailer. After over 45 years riding two wheels, this should be a treat.
Oh, I think with that setup you'll be fine. I've always gone for a center of gravity a bit in front of the axle(s) towards the tongue. I'm not an expert but I've towed a few RV trailers in my time and that's how they all seem to be balanced. My Kendon Spyder specific trailer is that way too and I never even know it's there most of the time.
That trailer deck looks like it is sit pretty low and the ramps are long, so you should have no issues loading it. There are two things to be concerned about on higher trailers with shorter ramps, the first is the nose hitting before the front wheels start raising it up, and second is the shift thingy that hangs down under the Spyder. That shift thingy can hit at the break over point and it is costly to replace it.
Yes, it does sit pretty low, although it is propped up high enough at the tongue so my truck hitch will go under it to lower it onto the ball, maybe 2” higher than the ball, but that is an option to simply disconnect from truck and raise the tongue if necessary. I will watch now for the shift thingy clearance. Thanks.
If the ramp looks too steep, I'd advise backing up to a curb so the trailer is lower in the street & the ramps are on curb, a good 2 inches or so higher. Disconnecting & loading could do multiple bad things - Rolling into the vehicle; tipping & slamming it back down like a teeter-tottering... PLEASE keep it connected, you can lower the tongue jack & raise the hitch a small amount while it's still attached. Having not ridden a Spyder, you don’t want to try & learn while loading. Others have said it will handle similar to a snowmobile - sorry, I have no experience with them here in LoUiSiAna, but similar to a 4-wheeler, yes! Depending on the condition of the rear tire, questionable traction might arise & I'd caution against just revving it too much.
