RangerRick
Well, I increased the spring tension by 6 turns, it still bottoms out on very rough surface, as in wash board gravel roads. Marcus's instructions say if you do more than 4 turns you may need a different spring, contact him. Well that is no longer an option. So for now, I am putting back on the stock spring, then will look to see if there is any info on his spring, I'm sure he purchased them from a supplier. The stock spring is bigger and 2 stage. What a difference in these two springs, no wonder his shock bottoms out.
